Originally posted by UNGN
If your car runs quicker than 110 mph in the 1/4 mile and does not have ported heads or cam, it will likely be quicker and faster in the 1/4 mile with 28" tires vs. 26" tires. Because most stock motored TR's trap way over their peak HP Rpm, the taller tires help the motor stay in the power band longer. Loose converter and weak valvespring cars are also faster with 28" tires (even if they don't run 110 in the 1/4 with 26" tires)
Because 28" tires reduce the overall rear reduction and provide a longer contact patch, they are more likely to withstand a high boost launch than 26" tires, so even 1/8 mile ET's can be improved.
My best average 60 ft times and my quickest 1/8th mile times are with 28" tires and my best 28" 1/4 mile trap speed is nearly 5 mph over my best 26" tire trap speed. 28" tires can work better on both ends of the track.
28X9 slicks or 28X10.5 ET street both fit fine on stock T rims, as do 28" tall 275/60 BFGDR's.
I have some charts and graphs on my G-body home page that goes into the comparison a little deeper.
