Tnetics Ext Wastegate and Boost Bontroller
87WE4BOOSTED
I NEED MORE BOOST!!
Alright, I have the new DP in with the external wastegate on and the boost controller installed just like the diagram stated. First question is, do I still use the factory wastegate solenoid in this mix? :confused: Or is it elimanated and controlled by the boost controller? :confused: Second question is, which psi spring will I use if I'm trying to get 18-20lbs of boost? :confused: Last question would be how should I start with a basic setting between the wastegate and boost controller?:confused:
Thanks for any feedback..
