To Much Boost
nhdecarli
Hello, forgive my ignorance first time messing with a turbo. 1997 GN, family car been sitting 15 years, 18k miles, engine light is on, code I believe to be 31 which is wastegate fail/overboost? Seems to run as should otherwise.
I disconnected the wastegate arm, pulls outward with easy, but resistance as I would expect for 13lbs ( i beleve I read) and the other end seems to move freely within the tube.
I replaced ( with non OEM hose) the 3 vacuum lines, using the factory Tee. I beleiev I have them re-connected correctly. Straight side of the "T" down to the wastegate, and top port of the solenoid. the other "off shoot" of the hoses to the bottom. I re-usewd the 90 and short piece of hose. Reset the engine light, and same thing. 15lbs+ boost and through the code again. Any suggestions moving forward? Thank you in advance!
Does the puck move freely w/ the actuator disconnected, or is that what you said?
