To the track in my stock t-type
rb68rr
Kinda bored, so I took the t-type to the track today just to see what it would do with some M/T et drags. The only mods to this car is the upgraded fuel pump, (hot-wired), adjustable wastegate rod, and adjustable fuel pressure regulator. In fact, it still has the original cat with 126,000 miles. I got the boost built up to about 5 psi while staging and then as the lights started down I floor boarded it. Boost went to around 9-10 psi as I left. BTW, we were running straight into a 25-30 mph head wind. I was running 20 psi of boost with a Thrasher 100 chip on 100 unleaded fuel. Tires had 13.5 psi. Results:
60 ft. 1.8874
330 ft. 5.3632
1/8 et. 8.3651
1/8 mph 81.36
I know this times aren't anything special, but it felt pretty good for an old grey stock t-type. Just wanted to share! Thanks, R.B.
SWEET!!! It's always fun to take any car to the track and run! Not bad times either. A lot of guys have a hard time getting their 60 ft down below 2.00, so you are off to a good start. Congrats!!! :cool:
