b4black
- May 24, 2001
Last fall, I installed a Tomco EGR valve. I like this valve because the backpressure transducer is external. The exhaust back pressure and the exact vacuum to the valve can be monitored.
I hooked up a vacuum gauge to see when the valve is open. Never. The valve is already dead. (I think it has a lifetime warrenty.)
In the meantime, I hooked the gauge up to the EGR solenoid to see when it should open.
At idle - off
very light throttle to heavy throttle - on
WOT - off again
The transducer blocks vacuum to the valve at zero backpressure. With a turbo, there almost always is backpressure. I might try running just the valve and no trandsucer. Keep it simple.
At idle - off
WOT - off again
