BaldMenace
- Sep 25, 2013
I have a brand new Garrett GBC37-900 67MM with a .82 AR. This was bought for my turbocharged Buick 300 build which has stalled while waiting for backordered parts. I'd like to use it with my 4.1 if it won't be lazy on the street and if it's not a horrible mismatch. My specs are as follows.
66 Special. 3500 lbs weight
3.830 bore
8.5 compression
3.625 stroke
Internally balanced
Molnar 6.350 rods
ported heads & intake
accufab plenum
70 mm throttle body
Hydraulic Roller cam 210/212
T&D 1.65 roller rockers
th400. 1700/2800 stall
3.42 gears
MS3pro-Evo with 80lb injectors, coil on plug ignition with smart coils.
3.830 bore
8.5 compression
3.625 stroke
Internally balanced
Molnar 6.350 rods
accufab plenum
70 mm throttle body
3.42 gears
