Toow hook
SS/GN
How do you tow one of these cars with a strap,at the track IF you have a problem or winch it onto a trailer:confused:.Any way I can see will damage a front air dam or something:eek:Thanks
Kevin
If I remember Kirbans use to sell something,but cannot seem to find it or any info on it:confused:
Kevin
These work. You can cut it and weld on an extention so it clears the front air damn. The ones Kirbain used to sell hooked on with the T if I remember right. It just was longer to clear.
Towing Frame Hooks | Truck n Tow.com
Any idea of dimensions?That hook to go through the center hole under engine has to hang down 6 inches to clear a STL intercooler:confused:Thanks
Kevin
The T goes into the slots in the frame that are in several spots front and back.
