top engine cleaner?
Turbo Brian
What do I type here?
got a question about the top engine cleaner. now, i read the directions at gnttype. what im concerned about is the part where i pour the stuff into my uppipe. i have an alky kit going into the uppipe. will this stuff in anyway harm the nozzle?
also, its a good idea to change the plugs and o2 sensor afterward, right?
Shouldn't hurt the nozzle it's mostly Naptha.
At least check the plugs and if you have a new O2 it wouldn't hurt but I don't always use one.
If you are running alky. you probably don't have to do the cleaner since alky. with water should do it for you. :)
