SignUp Now!Who sells an engine torque strap for the TTA? Or is it the same as the GN strap? I have an 87 GN engine in my 90 Firebird and am getting some knock that may be false due to a big DP and a worn pass side engine mount. Thanks!!
My Brother made this, it's worked great. easy to hook up. design is simple. picks...
Do you get a lot of vibrations with that setup as there is no rubber bushings or similar. Also where did you buy that type of turn buckle?
Thats a cool setup, I may look into that. Does that mess w/ the alignment any? It is pulling on the strut right?
I haven't had any issues with it. Some people use a tie down strap connected to the same way, not pointing down but over. turbotransam.com had a thread that showed it a while back. may post a thread there inquiring as to what others are doing.
Heck yes!! I picked up the parts for it today @ Lowes. $6 for the stainless steel turnbuckle, $1.55 for an eye bolt. I have some 1/8" Flat stock already so saved some cash there!!! I'll slap her together tomorrow!!
