Tps question.
ALblackT
My scan master instructions say to set the tps to .42 closed, and 4.8 wot. If I set it to.42, I'm only at 4.26 wot. Which one do I do?
Anything over 4.o WOT is considered acceptable. You're good to go :)
No floor mat, but I do have some fuzzy ass carpet. No improvements with higher voltage at wot?
Lose in both the screws holding the tps.
And pull it forward then reset
Like 626gn said 4.26 volts WOT is enough. You don't need 4.8. My car is at 4.20v and runs 10.90's :)
Thanks guys. Just making sure I have as many things right as possible so I can sort out what isn't.
Sent from my SAMSUNG-SGH-I727 using TurboBuick Mobile mobile app
4.8 is to high and will set off the SES. 4.2 to 4.6 is ideal. Jute, carpet and floor mats tend to get in the way of getting it to the floor.
I've been up to 4.8 before without throwing a code but results may vary.
