Rickerbucks
- Feb 18, 2003
Hi guys
I have been told by two sources that the Fast will read the TPS as 15% at idle and peaks at between 85% and 90% at WOT and that it is not a problem.
That just seems strange.
When I was using LT1 Edit to tune my TA it read 0 - 100%. is it because the FAST is speed density rather then using a MAF?
So the question is, does the TPS have to be calibrated as 0 -100% or is the 15- 85% FAST reading not a problem?
