I raced my car last Friday and had some problems. The TPS voltage was dropping under full throttle. I'm pretty confident I wasn't lifting on the gas. I've got over 400 passes and 10+ years of racing my car and the TPS has always been 4.76-4.77 volts at full throttle on all the passes. I haven't touched the TPS since I set it 10+ years ago. I also remove my floor mat prior to racing to prevent interferance. I was using TurboLink for all the data below.
race #1: started at 4.74 volts - went down to 4.52 volts at the end of qtr
race #2: started at 4.74 volts - went down to 4.68 volts at the end of qtr
race #3: started at 4.70 volts - went down to 4.62 volts at the end of qtr
Any ideas why the TPS voltage would drop? The sensor going bad or bad ecm?
I also had some huge spark retard on the 1st pass. On race #1 the second frame of the pass I got 40 degrees or spark retard. I noticed the rpm was 3950 at 18 mph. On the third frame the rpm was also 3950 but at 37 mph with 6.8 degrees of spark retard. The car seemed like it was stuck in 1st gear and not accellerating. The transmission is original and doesn't shift perfect anymore. The car has acted this way before on the street but no scan tool was hooked up at the time. What would cause the hanging of rpm at 3950 from 18 to 37 mph? Or could this problem be related to the TPS issue or the transmission going out?
My car is an 87 T that has the stk turbo, injectors, downpipe, and intercooler. I was running Red Armstongs 93 chip for stk injectors and pump gas with 14 psi boost. On the 2nd pass I had no spark retard at all. The 3rd pass I had just a few degrees of spark retard in two or three frames.
Any suggestions would be greatly appreciated. I have TurboLink files of the three passes.
Thank you, Craig
Thank you, Craig
