No need to prick through the insulator. Just stick the pin/paper clip etc through the back of the connector where the wires go into it. Blue is the one with the #'s you will be needing to test. Just turn the car to "run" without starting the car. Put the + lead of the meter on the back probe and the - on a ground. Take a reading at idle and then take one at WOT.
