Darkside8889
- Jul 12, 2004
Welp, I took the car to the track last night and was rather disappointed. Somewhere between work and the strip I managed to loose 6 pounds of boost and roared off 3 blistering 15.80-90's right at 90 MPH.
No knock at all on scanmaster, O2's staying above .800
Engine temp was 220 on all runs due to crappy staging lanes, I never got above 12 PSI on any run and it bogged like a mofo out of the hole even leaving at 2 PSI (street tires) (2.4-2.6 short times). I get the car on the highway leaving and get the tempature down to 180ish and all my boost is back and it pulls better in OD than it did in 2nd at the track.
This leads me to a few theories/questions
1. Boost limit due to engine temp in stock tune?
2. Lack of SA due to engine temp causing turbo not to spool properly, also lack of SA down low causing low end bog and lots of lag?
3. Way rich with 50# injectors and 50# constant but otherwise stock chip due to engine temp causing turbo not to spool properly?
If this seems right what is the .def file for the TTA and is it the same as the one for the GN ($T31 or $58 maybe???)? I have most of tunercat's def files and probably can fix this since it seems like a tuning issue, just need to find out what exactly the guy that I got the car from did to the chip
