track results from the new RJC BGC Power Plate?
Race Jace
Research, New Tech and Development
Staff member
Are there any? Just wondering how it worked for you guys. Cal?
Jason,
Is this useless under 1000HP. I like the piece, just want to make sure it is worth the Mod. THX:cool:
Originally posted by njturbo
Jason,
No, every car benefits from equal airflow distribution regardless of hp level. That is why (same as with our other plates) this plate has no downsides on any car regardless of hp level. It works well with everyones combination.
Thank you maybe Santa will bring me one. :D
BGC manifold
your plate for the BGC is looks great in the pics,I was told also that the manifold was not good for 109 block engines. I took that as they are meant for engines over 850-1000???? HP. :confused:
The BGC Power Plate will now be standard fare on the engines I build with that intake. Just like the standard Power Plate being installed on every stock block I build.
So far, I have 21 passes on my engine since installing the BGC Power Plate without any problems, none, nada, zilch. Once I get my 6 EGT probes installed, I will be able to give much more accurate data (Like the Bamfords did). Over the Hollidays, I will be installing a boost guage UNDER the plate and see if there is any pressure drop (doubtful). Sunday, I will be on the dyno and should have more feedback on the hp.
