BuickMike231
60% of the time, it works every time.
- Feb 21, 2007
Hey guys, I have a question for you regarding my tranny. When the car is first fired up it seems to shift and operate just fine, I messed with the TV cable a while ago and the shifts are in a good spot, not too loose or tight. What is weird is once the car has been driven for a little bit, like around 40 minutes or so, it starts acting up. If I let off the gas and get back onto it just cruising around, it almost feels like a manual car that gets shifted too early and kind of chugs while the motor catches up. In between shifts it is fine. This starts to do this once everything has been driven for a little bit, could this still be a TV cable situation? The fluid level looks good, maybe a bit high but nothing excessive, could that be getting too hot and acting up? Not sure if anyone has had similar experience but wanted to see what you guys thought! Thanks!
