I'm having a problem with tranny fluid leaking out of the pass side exhaust pipe?
When I shut off the car I get a slight drip.
How is this possable?
What could be wrong?
I'd be more inclined to believe that you have one of the transmission lines leaking onto the exhaust and dripping off, since they in the vicinity of the exhaust. Good Luck!
That would make sence if it was dripping in the middle of the car, but my leak is comming from the tail pipe itself (from the tip). The exhaust pipe is dry 1" before the tip to the front of the car.
From iside the exhaust tip or on the outside? I think you have a leak somewhere that is leaking onto the exhaust as stated above. Ever looked under a car after it has leaked? Depending on how clean it was before you can see how the airstream just blows everything back and coats it after something leaks.
Jack it up and check it out.
Also check that all the plugs and lines are tight in your trans I had a plug that was missing on my trans which caused fluid to shoot out onto the cat and drip down. Pretty messy.
