Tranny Gone, Damage Report
ZR1TR
Leaving a friend's house last night, I was in 1st and gave it part throttle and all of a sudden the transmission felt like it popped out of gear. I put it in neutral and then back in drive. Nothing there in any gears, it just rolled down the hill. No leaking under the car, doesn't smell like anything is smoked, and there's fluid on the dipstick. I know this has happened to one of you. There is a whining sound coming from under the drivers floorboard right behind the front wheel. Any help?
Jonathan
yuck...
Forward drum shaft, input shaft, tq splines, od planet splines, stator shaft support splines or pump rotor failure. Any one of the these.
But, it is coming out and torn down to discover which one. First you may want to see if you have any line pressure. That would at lest narrow it down , however, it isa comin out.
Bummer
Bruce
WE4
PTS XTREME
