Vendor Defendor
Out the window
- Nov 25, 2002
I can’t seem to win with this transmission... I figured I could have done this the cheap/hard way, and build a tranny myself but I can’t seem to get anything to go right
at first the car had a bunch of leaks... I think I have fixed all of them, but I don’t know if I have got them all, I will know in the morning, when I look under the car....
Then reverse wasn’t working... so while fixing the pan gasket leak I dropped the valve body (on me) and tried to see if I installed that little rubber piece that goes in the channels for the low reverse assembly incorrectly...
So I look at my old tranny, and it looks like the silver piece is facing up, but I couldn’t pull it out to confirm this.... I looked at the one in my tranny is it looks like it’s in there right... so I don’t know, maybe this is the part I screwed up... does the silver part go up or down for low-reverse??? I put it up...
When i got everything buttoned up, I backed it out of the driveway, and put it out on the street, put it in park, let it idle, checked the fluid, added some... backed it up about 20-30 feet, drove around the block, checked the fluid, added fluid, backed up 20-30 feet, around the block, and this process happened about 4 times or so...
When I thought the car was full on fluid I drove it around, everything seemed pretty good. went about 2 miles, to a local car show, stopped in a parking spot, called some one, got off the phone, put the car in reverse, no reverse..
Now, I thought this was kind of odd, but maybe it’s right because I dropped the valve body and what not. But I thought the stock pan only held 6 quarts of fluid? It took 9 quarts…
Perhaps I am just low on fluid... I will check first thing in the morning. I don’t know what could possibly be wrong, if it’s not the fluid problem.
The tranny has an AA case, CZ valve body, a GN governor, Alto wide band, raybestos clutches, a CK performance shift kit and a 2800 stall converter…
Can you give me any clues on what could possibly be wrong? Any help is greatly appreciated... I just want to get my car running good and strong. Just doesn’t seem like it can happen... Like I said, maybe I shouldn’t try and do this stuff myself, and get a professional to do it...
I don’t know if I left anything out of this, if I did, I will add it once I remember... PLEASE HELP!! I really need help guys…
Thanks again for trying to help…
-Neil
-Neil
