Tranny Line Leak, Help!!
Yedi
ya, the Monte over there.
I just put in a new Aluminum Radiator, it was a direct replacement for the one I had. It's a One row with the built in Tranny cooler. I hooked up the lines to the radiator from the tranny and the bottom one is leaking a little. I checked it and it's tight. ( not crossthreaded)
Could the flange on my line be bad, if so can I run a piece of hose with a new line/flange to the radiator? Or is this too much pressure for this. Or if there is any other way of fixing this I would be greatful. THANKS
You can use a short length of hose to make the connection. Just be sure you use hose rated for use with tranny fluid.
Two other options are cutting and reflaring your line or replacing it altogether if it's shot.
