I noticed on my TTA when I installed the tranny that the trans lines on my car do not go to the radiator. They were routed to lines on the LH fender-well going to a tranny cooler is this correct or did someone re-route them this way? The radiator has plugs on the RH side of it but I always thought it was because the previous owner removed the oil cooler and the oil cooler lines went there. If the tranny lines are suppose to go into the radiator should I route them that way or will it be fine just going to the tranny cooler? The cooler is mounted up against the radiator with the supplied hold down straps. Thanks, Jason
