This is car # 3 for 2001 black/ black a4 t-top. If you walked up on this car inside/ out you would say it has 10,000 miles on it at most. It has been garage kept at home and at work. I never follow people close fo not beat up!!. It has never Ever broke down. Has several mods all done with the great care. I have been told this is one of the fastest bolt on hawks . Under drive pulleys, moroso wires,SLP smooth bellows, SLP 85 MM maf, SLP lid , SLP filter, Kooks 1 7/8 long tube headers and y pipe, electric cutout, SLP factory I-pipe back. Level 3 rebuild on the trans about 6,000 miles ago, 3600 stall yank converter, 3.73 gears, auburn diff, TA rear cover, rear is dead quiet. Brand new GM strut mounts, Koni yellow 4/4 1LE springs fronts set on lower perch hose moded rear. Stranos best hallow sway bars, hotchkis tower/tower brace, have there track bar trailing arms & sub frame connectors brand new never installed, car has gone 11.8's at 115.9 with this setup !!! no Joke, has heavy duty trans cooler, Micky Thompson drag radials 275/50/17's new tires up front all new rotors, hawk hp pads, new plugs,new belts. Installed a few weeks back. Car needs nothing, no dings, no dents, no rust, no accidents. This car has chrome wheels that was been washed and waxed inside / out with mothers since new they are 100% perfect. engine is perfect does not use one drop of oil, zero leaks Ice cold ac everything is 100% working. I have put it in several shows this past year and got best of class late model GM trophy.I have all documents from new dealer and SLP, invoice stickers, keys, remotes , books, birth card. trunk mat, floor mats all excellent. if you are serious and have the money or can get it and .We can meet so you can see the car in person, car is in pa 17329 zip stored in nice warm locked garage I would hope you do the same.
Comes with complete set of Firehawk decals NEW spares incase they were discontinued and they are now, extra NEW in box SLP Firehawk floor mats + ones in the car are perfect!. New trailing arms, new panard rod, new subframe connectors (none of this stuff was ever installed) it does have 129,000 miles
Pictures by gn4u2c - Photobucket
