trans bracket
97rebello
the piece on the trans where the cable hooks up and the linkage arm goes for the pn switch
i need pretty much everything from the bracket to the linkage i dont need the bracket to the pan just the shifter one
So you don't need the bracket on the pan and you do need the lever that turns to changes gears. Do you need the metal linkage also. I have those parts also.
