Adam Whitman
- Jun 10, 2001
I just had the front pump apart for a new bushing. Had the regulator apart and can't see where I assembled anything wrong, but...something stuck?
When in Park and Reverse it loads the engine like it is in gear but there is no driveshaft movement. Revving it drags the engine down like there is a trans-brake on.
In Neutral and D321 it wants to go forward by looking at the turning output shaft (waiting on driveshaft to be built). Engine free-revs like normal.
If you have it in neutral the output shaft is spinning (freewheeling I assume) and then put it in reverse the output shaft stops. But if you then shift into park you can hear the park pawl grinding like something is still spinning in there.
I can't say how it worked before I got it but know that it drove into the shop and was replaced with a TH400 along with an engine swap.
Help?
Help?
