Trans Brake Question
moose
How much would a trans brake help on my 60 ft compared to foot braking? I have never had a trans brake before and was considering one. I have the S-10 manual brake cylinders on mine and they do good but i'm not to up on what all would need to be done along with a trans brake to make it work it's best.
what are you 60fting now, how much boost are you leaving the line with on the foot brake?
I can leave on 5-7 lbs but it's kinda strange because my 1/8 ET is quicker when i leave on less boost? 60 foots are in the 180's. I'm wandering could my converter being a 3400 be hurting me and also could that be the reason for quicker ET's leaving on less boost is letting the converter work better?
My transmission is fresh with only 6000 miles on it, what kind of upgrades would i need in order to put a trans brake in it?
For durabilty Billet Input Shaft & Billet Shaft Forward Drum.
Strong U-Joints/driveshaft.
Install a line lock...it'll keep the rear brakes cool...watch how much more boost/rpm you can leave the line with.
