T
tyrantblack
Guest
ok who can explain this to me?
if the point of a high stall converter is A.) to allow the engine to get into it's power band and B.) allow you to build boost at the line, but if you where really only concerned with the latter then would not a trans brake serve you better w/ it unlimited boost building ability and then could you just use a lower stall speed converter for cruising? or is there some thing big here that i'm missing? Please explain, or is this though of mine correct?
