trans connector
That would work If I had the plug with the wires in it. I have a repacement plug, all wires the same color. I need to identify the terminals in the female connector in the trans.
P.S. I am using this transmission in a car with no computer. I will be wiring in a vacuum switch to control the lockup. Thanks
Plug pins on the trans are, Top Left=A, Top Right=B, Bottom Right=C, Bottom Left=D or clockwise direction ABCD.
A=12V to solenoid
B=ECM, not used
C=Not used
D=From ECM Ground to TCC solenoid, Not used, depends on which pressure switch, solenoid & wiring method used.
