Trans cooler hose does it matter what kind?
87gn-newbee
Does it matter what kind of hose you use or can you just use some fuel line? If not what kind of hose to use ? PSI rating?
Dan
I have used regular fuel line.
You should probably use fuel injection line, yeah the expensive stuff, since the pressure could get to 50 psi. I believe is the number quoted.
Short runs use the good rubber stuff worth the extra cost. :)
Long runs go braided stainless. :cool:
I would use rubber trans line at the least. It's the one with cords inside and is a harder line.
