Trans cooler line fittings
Pittsburghkid
Displacement Replacement.
I'm looking for the 90* fittings that go into the rad to connect the trans cooler lines and also the female to female fittings that connect the trans cooler lines to the trans cooler line extensions. Or if someone can atleast point me in the right direction to buy new. Thanks
You can get these from several of the major vendors.....I just got mine from
www.GBodyparts.com
The transmission line couplings are just female threaded both ends and can be found at any major automotive supply house.
I got them if you need them but there used.
I got only the 90's the line connectors can be found pretty easy at any auto parts store. The fittings are a bit dirty but brass cleans up nice with a wire wheel. $10 for the two and $3.00 to mail them to you.
Let me know.
