Trans cooler
buickboy92
A transmission cooler out of a ford f150 fits perfect in the core support not sure what year it was out of ill find out
be very careful using used coolers!
When I worked at a remanufactured transmission company, clogged cooler and related trash was one of the biggest reasons for transmission failures.
As long as you make sure you run it thru a parts cleaner you should be OK.
