J
Jims89tta
Guest
Hello,
I have a 1989 TTA with a 200r4, all stock 86,xxx miles. I changed the fluid and filter last week, it was blood red at the time of the change. I filled it up properly and checked the level 2 days later, hot and running, it was fine. Yesterday I drove to the store 4 miles away, when leaving the store reverse worked fine.
The problem is the forward gears, all 4 just slip. You have to get the rpm's up to 2000+ to get the car forward. I check the fluid right then, level was fine and blood red. I messed with the tv cable and no change. So I drove home slipping in drive, fluid now is a little burned from the drive home.
The filter is seated right and I did change the o-ring out. No parts were in the bottom of the pan, just a little super fine black powder on the magnet.
Any help is appreciated.
Thanks,
Jim
Thanks,
Jim
