Trans line Return Or Feed?
87chrisss
BLUBYU
Can someone help me out with this, im not under the car but im not sure which one is which and which port on radiator does it belong to?
thank you sir, very helpful!
By any chance do you know which port is feed and return on the radiator, im guessing the same, top is feed bottom is return
I'm not sure on that. I haven't used the stock cooler in a long time.
So you just use the external cooler? Thats what i use, but from reading ive noticed the water cools alot better than air does on an external cooler.
It probably does. I've never paid any attention to it.
I believe the connection on the bottom of the radiator is the feed & top is return. You want any air that could be trapped able to disperse easily as it's going thru the rad cooler....having the in on the bottom allows this as any air bubbles present will rise as it flows thru the rad cooler tank.
