Nov 26, 2011 #1 S S10xGN RETIRED! Joined May 26, 2001 Messages 2,563 Quick question, doing a filter change and also swapped the cork pan gasket for a fiber one. What do you like for torque value on the bolts?
Nov 26, 2011 #3 S S10xGN RETIRED! Joined May 26, 2001 Messages 2,563 Bill_Ritter said: 100 in/lbs Click to expand... Wow, that was quick! I went 96 in/lbs, but the truck is still up in the air while I fix the exhaust system...
Nov 27, 2011 #4 C charlief1 RIP Charlie! Joined Sep 20, 2007 Messages 23,936 You'll probibly laugh at this, but I use one of those flexable spring type extentions (1/4") and when you tighten it the spring will twist just enough. Never actually measured it myself but I've never had an issue doing it this way.
