Trans pooped out
  • Thread starter Thread starter Jims89tta
  • Start date Start date
J
Jims89tta
Guest
Hello,
I have a 1989 TTA with a 200r4, all stock 86,xxx miles. I changed the fluid and filter last week, it was blood red at the time of the change. I filled it up properly and checked the level 2 days later, hot and running, it was fine. Yesterday I drove to the store 4 miles away, when leaving the store reverse worked fine.
The problem is the forward gears, all 4 just slip. You have to get the rpm's up to 2000+ to get the car forward. I check the fluid right then, level was fine and blood red. I messed with the tv cable and no change. So I drove home slipping in drive, fluid now is a little burned from the drive home.
The filter is seated right and I did change the o-ring out. No parts were in the bottom of the pan, just a little super fine black powder on the magnet.
Any help is appreciated.
Thanks,
Jim
When you put the new filter in, there wasn't by chance one of the old O rings mistakenly left behind up in the hole was there??
Well........
I pulled the pan, found lots of black metal powder, lots. I checked if the filter was all the way on, it was. I pulled the filter and checked the oring "I installed" the oring was there just the 1 oring. I inspected the filter, after cleaning it, no cracks.
No extra "stuff" like springs or metal chunks in the pan. Just loads of powder. I will just have one of the TB Guru's rebuild and beef the trans, when I get the cash. Might be 6 months out. Oh well I will be overseas on business for 3 of them.
Thanks for all you help guys!:)
Jim
