SignUp Now!Wanting to get some opinions from some of the members on some of the pros and cons of having a transbrake for a street car and sees some track time. Jr.
. The manual brake inherently has a HUGE delay in it . The manual brake also has a TON of rollout in it!
If your putting the manual brake in a trans with high mileage that may be true, however if you put it in a low mileage or new built trans with a decent builder and tight clutch clearances in the low/rev, direct,and overrun, the trans will lock right down on the brake and leave quick {without shudder}.
At the time, my tranny was tight, all new parts, billet drums, etc. I still didn't like the fact that when you engage it, there was too much fore and aft movement.
Sorry, but I hated the thing. Slow to react and sloppy all the way around.
Went back to foot braking and got back to winning.
Manual trans brakes are fun, yes, but they absolutely suck for bracket racing.
That is why I do not like the "slam the shifter brake" Very dangerous and can be fatal!!!
THE BAT BRAKE,
Locks down with ZERO rollout and all the facts and specs are here. It is the fastest on the market. Ask the pros who run one.
Here are the facts and the whys:Product Information
This is the quickest and most consistent 2004R brake available. .028 Release time. As with any race product, there are certain steps that need to be followed to insure your success with it.
CAUTION
This or any transbrake should be installed by a qualified race transmission technician. If you are unfamiliar with any of the operations or terms, take your transmission to a qualified race trans shop. Improper installation may cause property damage or death.
2004R racing transmission brakes are designed for pro-tree or full-tree use. Delay may be achieved by an electronic delay device, a two stage ignition rpm limiter or by the driver picking the desired rpm and simultaneously mashing the throttle and letting go of the switch at the desired spot on the tree.
Product Information
Just thought might be interesting reading. For any more info , go DIRECTLY to the source, ME! call and I will give anybody the time and tech to answer any and all questions involving the operation thereof.
Ask the pros.
Ask Janis, Kurtz, Dynotech's Eric Shertz, ask Red Armstrong, This is the quality of people using this product.
The Product does all the talking. Period!
Ask and run with the winners.
Bruce
WE4
Performance Transmission Services
