Yankee John
- Sep 17, 2008
I bought a used Translator plus (no idea what version) from a board member and installed it along with an LT1 MAF today. As a side note, with the original MAF, My car had a slightly rough idle and an occasional miss while idling. Sorta like a car with a hot cam in it.
I set the Translator unit to the base settings for my combo; dip switches on, on, on, off, then the Base switch to number "3" for the 3" LT1 MAF, and then the WOT switch to "0" no change.
When I started it up, It idled like crap- barely ran at all. I tried the other settings for the 3" MAF , but no change. I then tried the 3.5" MAF settings, and I found that it idled great when set on #1- For the 3.5" sensor with 10% rich at idle.
Is it unusual for the car to run better on a Translator setting for different size MAF, or does it indicate that I may have other problems? It idles pretty nice now, although a bit low for my tastes (fluctuates between 575-625 RPM). I'm certain that I have vacumn leak(s).
Thanks in advance for any advice and comments!
John
John
