I have checked all the wires and there all good
I have also checked the bypass wire from ign mod to ECM all fuses cam sensor and replaced crank sensor
I solder the EST and to and from the ECM/ign mod
Yes I did get a check engine light with that code
the car seem to run very very very lean my EGT was reading 14,500 @ 50 mph with no boost and the car had no power
her is the messed up part it would go away and run fine
after the 4th ign mod.
I now have a ign mod that will give me a spark but it is like the timing is off or misfiring it dosent make sense
can any one tell me what the ESC (Electronic Spark Control)
mod. does and is it part or all of my problem
this part is located next to the fuel pump realy and the map sensor
my next step is too replace the ECM
thanks for the help
