Transmission Fluid
USMC_Turbo6
HAs anyone ever uesd Lucas Semi-Synthetic Automatic Transmission Fluid.
Here is what I wound on the web site.
Designed to withstand high temperatures and pressure. Excellent for high performance transmissions. Greatly extends transmission life and fluid life in truck and passenger car use. A real money-saver.
This is no normal ATF formulation. It has been developed to give the smooth, precise shifts needed by ET racers and yet extends a degree of protection not found in any other ATF. This product will stop wear and tear like nothing you've ever tried.
GM is supposed to have or coming out with dextron 6 which should be very similar in performance and protection.
