1983 Buick Regal T-Type turbo 6 extra clean survivor 67k miles
type83t
Http:\\www.ttype.homestead.com
Ton of photos to review
http://www.flickr.com/photos/nomad55/sets/72157630036210304/
http://www.ebay.com/sch/cpseo/m.html?_ipg=50&_sop=12&_rdc=1
1983 Buick Regal T-Type 3.8L Turbocharged V6
s/n 1G4AK4787DH839146
67,000 ORIGINAL MILES – 2nd owner
OPTIONS: A/C, Cruise, PS, PB, original AM/FM Cassette
=====> FOR SALE <=====
ENGINE: Buick 231 3.8L V-6 turbocharged (original) Rebuilt at 65,400 miles
Balanced, Block Align Bored and Decked – painted with POR-15 Engine Paint
Bored .030” over with Forged Aluminum Pistons and new Rings
Polished Crankshaft, all New Bearings and gaskets
Engine Machine work done by Precision Turbo & Engine in Hebron, Indiana
Performance Cam & Lifters (new), timing chain w/ roller cam button
APR Bolts for Heads / Rods, Cylinder Heads surfaced, valve job
Block Oil passage enlarged, improved oil pump gear for increased shaft lubrication
New EGR valve, knock sensor, Distributor cap/rotor, water pump
Intake manifold / Carburetor plenum bead blasted, clear coated in high temp paint
Carburetor rebuilt – Stock Electronic Rochester Quadra jet
GM Remanufactured Turbocharger
EXHAUST: Jett-Hot Thermal Metallic ceramic coated downpipe*, cross over pipe, turbo inlet pipe* (*thermal wrapped), GM Factory Dual Resonator System, factory headers and convertor (hallowed out) are powder coated high temp satin black.
POWER COATING: Chrome Silver w/ clear coat powdered coating over the top: Valve Covers, All front accessory brackets, fan, thermostat housing. GLOSS BLACK: Oil Pan, Air Cleaner housing, Front & Sway Bar, Drive Shaft, Other parts have been painted with POR-15 black
TRANSMISSION: GM 200R4 four-speed overdrive (original) rebuilt w/ BRF Grand National Valve body by Jimmy Transmissions – Shifts very firm. B&M drain plug kit, New Shift Cable
BODY: STRAIGHT SMOOTH BODY that is very solid. There is only a small amount of surface only rust where rear quarter panel folds under the body caused by rock chips (surface only). There is an insignificant amount in each door in the seam area where the door skin is pinched on at the corner, nothing serious. No bodywork has ever been done to this car that I know of or does it have any bondo I can find. Pictures should show all this. The hood & trunk lid have crazing. I have not been able to get good pictures of the hood and trunk yet to show the paint condition I am talking about. It has a few chips and a small ding around the passenger side door key / handle. Review all the photos for complete details. The plastic bumper fillers have been replaced and repainted with aftermarket ABS parts.
INTERIOR: Excellent condition and CLEAN! Headliner reglued, Sun Tachometer added in dash in place of clock (have original clock), pillar mounted VDO Boost gauge, original GM floor mats. A/C works / blows ice cold ans still uses R-12!
CHASSIS / TIRES: GENERAL 235/60/15 XP2000 Radial, Front Frame painted with POR-15 and painted black, Front Sway bar powder coated gloss black – Black Poly frame bushings & End Links, Driveshaft: Powder coated black with new u-joints and new yoke. Tires are old and should ultimately be replaced due to age.
BRAKES: New Calipers, Rear cylinders, Brake Pads and Shoes, fluid flushed and bleed. stock GM Hydro boosted brakes, Master cylinder has been painted with POR-15 black, master cylinder cap powder coated gloss black (may now show in pictures as was installed later)
COOLING: Aluminum core F-Body radiator w/ 1-1/4” core and 6” wider that stock (Spectra Premium CU162), wider top fan shroud from 85-1/2 GN / Turbo Regal, NPG+ waterless coolant.
http://www.flickr.com/photos/nomad55/sets/72157608344889692/
NEW PARTS: Fuel Tank, Fuel Pump, New Bumper Fillers, Hood Gas Cylinders, Hood Insulation (finally replaced Oct 2012)
Other: Factory Manuals / Parts Book, original paper work
What does it need: Carburetor tuned and checked out, I have not had time to fully get it tuned and it will leak down after it sits for a while making it harder to start. Cruise Control is all there but I have not got it functioning since it is back on the road. Headlight Bezels as the present ones have bad chrome.
$6400obo
FULL Details an Photos at http://ttype.homestead.com
