transmission help
martybo65
hi the tranny that came in 87 moticalo ss czf would it shift a work fine on my 87 gn ?
Auto shifts at WOT may be a little higher than you want. The CZ code usually shifts at about 5500rpm @WOT. Other wise it will work fine. I'm not sure what swapping in the GN's BR code Governor will do in the CZ code Trans, someone may know.
