I FINALLY got my transmission back, and into the car. I cut the old lines (as the nuts was in such a bad shape that I could not loosen them), but after all this wainting, I´ve forgot how the lines for the oil cooling was routed.
On the transmission:
The upper is hot oil out, and should go to the upper on the radiator?
The lower is cooled oil in, and should come from the lower on the radiator?
I also have a large SOB cooler infront of the radiator
Thanks,
/Andreas, VERY confused
Thanks,
