fastblackcar
Never Finished!!
- Mar 12, 2006
I'm pulling the trans from my car, i noticed the original universals are still intact,i'm thinking i should replace these while its apart, what are some common replacements that are durable? Im taking the trans out to replace the Torque converter, my trans shifts excellent, easy gets rubber in 2nd, how can i tell if it has a shift kit already installed? the gnttype site shows adding a trans cooler in line with the factory one just adding it into the top line, would it be better to completely bypass the factory unit? Im also wondering about the front pump seal anything better then the one from advanced auto ? Thanx for any input !!
