So the car has sat pretty much for 1.5 years...heated garage. Got it all spruced up and ready for the track and headed off to Indy. Car started and ran trouble free for 60 miles. Got to the track and decided to do my first run at 100% street setup and boost limited to 17.5. As a precaution I dumped in 5 gallons of pure C16 that was 1.5 years old. Gas left in the tank was about 3 gallons of a mix of brand new and 1.5 years old.
Start the car and head to staging lanes. Get in line and shut off. Restart to move ahead a couple times. Somewhere in there the check trouble light came on...thought it may be the C16 killing the Oxygen sensor...car still ran OK. Then the car died. Restarted...died. Restarted...died. I got to within 4 cars of the starting line and it would NOT restart. Pushed it backwards out of line...not the way the mighty Buick should travel!!
Car would start but die....sort of the way it does when anti-theft device is engaged. Overroad the anti-theft device repeatedly to be sure it wasn't my problem. Suspecting that the 1.5 year old C16 was the problem I drained it all and replaced with 5 gallons of brand new C16 I bought at that moment from the track. Didn't make any difference. Eventually hooked up the hose to the fuel rail drain to see if I had good gas supply. And here is the very interesting part.
With the hose connected to the fuel rail the pump pushed fuel into the tank for 2 seconds on initial key on...just like it's supposed to. Then I turned the key a bit more to start and it started immediately and continued to run and accelerate with a steady stream of fuel coming from the fuel rail hose into the gas can. Thinking we had "solved" the problem....even though we didn't know what the problem was...we removed the hose and reinstalled the fuel rail cap. Wouldn't start. Put the hose back on and it started. Cap back on the fuel rail and again no start. Reduced fuel pressure at the regulator to about 30 psi and it sort of seemed to start and run just a little but basically there was no change...wouldn't start. FP had been at 45 (line on) like it has been for 5 years or more. So reinstalled the hose for the 3rd time and it started immediately and ran fine. While running I kinked the fuel drain hose near the gas can and car died immediately!!! Replaced the cap, and put tools away.
Gave up at this point and arranged for a tow back home after end of racing. Friend and I left the car in place and watched the racing for 30-45 minutes. Went back to the car and it started perfectly. Shut off and restarted. No "check engine light". Told the "guy" we weren't gonna need a tow and headed home. Stopped nearby to drain the brand new C16 and partially filled tank with 93 octane. Drove 60 miles home with no problems. Driving thru hometown at 35 MPH, steady speed, no throttle changes, no radio station changing, nothing at all going on and the car died. Coasted to a parking lot...where I tried to restart. Would not restart. Reset anti-theft device and it started immediately. Drove another 15 miles to drop off friend and go home with no problems.
So WTF is that all about??
Anti-theft is a feature in the ECM....have had it for 10 plus years with no problems.
Thanks for any insight, Bob
