SignUp Now!Theft deterent?? the only two wire connection I'm familiar with back there is the electric trunk release.
See what happens to the memory with advanced age!
Thanks savage v6. Not sure whats up with the other responces, they were probably +++++++++++++++++It grounds when forced. otherwise it's a normally open connection.
Black wire is a ground cavity B, light blue wire with black stripe cavity A goes to a connector C604
It joins into connector C600 for the front drivers door tamper switch before the splice from the right/pass. side switch then onto Pin J the arm and tamper input to the theft deterent controller.
C600 and C604 are in the drivers side footwell area under the same area the ECM would be in for the pass side.
Left of the fuse panel.
diagram
How exactly does the two wire theft deterent connection on the lock cylinder?
X2, Ray, I didn't understand the question either.Just like what I have. Thanks, didn't understand until this post
Guess I'm going to have to take a closer look at my 87's trunk lid. I only remember seeing the wires for the electric trunk release and the trunk light. the 87 is security equipped.
