trunk lock cyl with factory alarm
The truck lock cylinder is the same on all Buicks. Alarm or not. I have a truck cylinder if you need one.
Its only the door locks where the cyclinder is longer so that the electrical connection to the factory alarm can fit around them.
the cars with factory alarm the lock cyl has a thin long sping with a wire threw it that connects to the factory alarm system there a wierd hard piece to find ill have to see if i can find the picture when i removed mine i found a couple but everyone who has it wants to sell everything in a kit to convert a car
You are correct on the two doors it has the wires hooked to the cylinder and the clip that holds the cylinder to the door has a harness plug too. BUT the truck lock does not have this and the 1st post you stated that your looking for a "trunk lock cylinder" with factory alarm. Like I said the truck lock is a regular cylinder. I might have one or two door lock cylinders for the factory alarm but I do not have any of the wiring other than what on my car. PM me if you need any of the cylinders.
