SignUp Now!thanks. i have a very limited knowledge of the tuning and electronics on these cars. what exactly does the wideband do?
Yes that is my car at Cayuga, a long time ago. The wide band is an extra oxygen sensor that goes in the down pipe. TT has a special chip that you can program, and it will tune the engine for you up to a certain point. If your fuel system is not enough it will add fuel or subtract fuel to the injectors to get the best air to fuel ratio for your engine, but it has limitations, but its better than guessing your tune. The factory o2 sensor is only accurate on a very narrow range and the wideband is accurate in all ranges basically. You can have a scanmaster and power logger and wide band all connected together working for you all at once. You will need a laptop in the car to record your data with the power logger, and post logs on the board here and people will determine for you what you can do to improve your tune, but if you plan to increase boost the steps that pronto outlined must be followed, or pay the price of new HG. Your car looks like its got a lot done so now is the time maybe to get serious tracking whats going on in the ecu to see whats safe and what is borderline.
