Tt chip
mr.La Rue
I'm trying too get a tt chip so i can run a 86/87 ecm but there is something i need too know.
What is the type and part # for stock 84/85 injctors
What is the stock can and spec
Stock # not sure but just fill in 28lbs/stock injectors when your ordering the Chip.
I think you mean CAM no can. Don't know the spec but it's fine up until low 10s i believe. Also fill in stock cam when ordering, Eric will know what you mean, also will double check with you before anything.
Why not get Bigger injectors off the bat? If not, atleast get a slightly bigger new set. The LEAST would be 30lbs if you plan not to upgrade the turbo, or 36-42lb injectors if you do plan to. Then again, 50's will be best investment.
Also Decide if you want the IAT sensor burnt off the chip, 86/87 had a sensor that reads intake air temps, which you could install but really don't need it. I think most of us running the 86 ECM had it burnt off, just ask Eric to do so.
I just ordered a TT chip from TurboTweakStore.com and I THINK if you answer the cam question with "OEM Stock" Eric will know what to do. On the injectors - There's a part number on the injector but on mine it's VERY, VERY SMALL writing on the plug. You'll almost certainly have to pull the injector to see it. AND - (not to question your knowledge of your own car) but I'd want to see the number because injectors seem to be one thing that almost everyone changes on these cars so unless it's a 1 owner you really want to make sure they haven't been changed... just my 2cents.
i just ordered a tt chip from turbotweakstore.com and i think if you answer the cam question with "oem stock" eric will know what to do. On the injectors - there's a part number on the injector but on mine it's very, very small writing on the plug. You'll almost certainly have to pull the injector to see it. And - (not to question your knowledge of your own car) but i'd want to see the number because injectors seem to be one thing that almost everyone changes on these cars so unless it's a 1 owner you really want to make sure they haven't been changed... Just my 2cents.
x2
