last nite was the first nite out with the car since last year when a bad injector took out a piston which in turn hurt the block beyond repair!!!
the weather was PERFRCT!!!!!! low 60's high 50's
had the car set at 17lbs boost and base time 23/21 with Eric new Y band chip
1st pass soft launch 2lbs 1.74 60ft went 7.40 at 93 1/8 and 11.50 @ 118 RICH!!!!!!!!!! 10.2 on y band and 800+ going threw the traps
2nd pass 3/4 lb launch 1.59 on M/T DRAG RADAILS!!!!! went 7.10@ 95 1/8 and 11.30@ 119 1/4 same boost 17lbs!!!!!!!!!!
this still using stock ecm, 60lb inj,67 turbo, and a MASS AIR SENSOR!!!!!!!
want to get about 6 more pass just to make sure every thing is good before I turn it up!!
will keep you all posted have a few more T/T and track rentals to go
so glad things are coming together I want to give big THANKS to Don Cruz for a new girdled short block and Razor for the BEST alky kit AROUND hands DOWN!!!!!!!!
thanks JD
__________________
SOLD!! 86 GN(GNX clone) 67 tubo,ALKYCONTROL,M/T D/R, 50's, RJC P/P,9/11 3400 con.,T/Tchip,NEW 11.66@116mph
NEW!! 86 GN (the new GNX ) te45a, fast bank to bank,bulit motor, billted roller cam, alky soon!!! numbers real soon, and the #'s are 12.63@111 on 16lbs and 93 only!!!!!
89 TTA 1092, 67 turbo,ALKYCONTROL,M/T D/R, 65's, RJC P/P,9/11 3500 con.,T/T chip,NEW BEST!! 10.85@124mph WOW!!!!
86 GN stock 161,000,basic's,13.20@100mph
thanks JD
__________________
