TTA Parts For Sale, long block (or parts) and wheels
RANDALL
Banned
  • Updated 2/6 all below are still For Sale
stock rotating assembly (crank/rods/pistons) - $400.00 OBO
stock intake w/Hemco plenum - $250.00 OBO
stock crank hub (external balance) - $50.00 OBO
stock flexplate (external balance) - $35.00 OBO
RJC power plate intake diffuser ADPPP (no gaskets) - $40.00 OBO
timing cover w/oil pump and water pump (no cam sensor) - $125.00 OBO
oil pan - $40.00
wheels - $850.00 OBO
- will consider OBO if interested in more than one part -
Shipping additional on all items.
I passed on this because it has GN pistons instead of TTA pistons. Sorry I misunderstood your post!
Where are you located I'm interested in maybe purchasing the entire short block from you . I just purchased my Trans Am and had an issue with it so I'm actually looking for the rolling assembly but I would possibly like to buy the entire short block from you if its still available I'm located in New York .
Were there any known issues with the motor prior to taking it apart ?
Is the crank cross drilled ?
Do you have the piston part number?
Do you know if the engine is the orig one to the car or was it a factory replacement or did it just have a crank kit installed ?
SG1 block came in the tta from factory
Aswell and the being used as the factory replacement for the buick
For gm warranty
Yes, crankshaft is crossdrilled. Rod and main journals have rolled fillets.
Number cast into pistons is 25531068, also has "Buick" in casting above number.
Motor is believed to be original., but I can't prove with documentation. Receipts mention a crank re-grind so I doubt rotating assembly was replaced with new.
