Jan Larsson
- Nov 22, 2001
Putting my engine back together (bottom end all done so far) but realised the clips holding the transmission cooler lines to the studs on the engine oil pan can face two ways and cant find any pictures of them anywhere. clips at front and rear of oil pan on the driver side.
Same goes for the clip that holds the starter motor wire harness in place, attached to the oil pan stud on the passanger side (front of engine just below engine mount).
See pictures below, all clips are probabrly black original I had the trans cooler line clips zink plated and the starter wire harness clip powder coated.
Anyway if you don't mind looking at your TTA and help out would be great so can get them installed the correct way. Just let me know if I got them right or wrong. Photos taken in engine stand with oil pan facing up so will be the other way around when installed in the car.
